The end is here from Xantia
imperial21
Unread post by imperial21 »
I think sadly my car has had its day, A very poor fail :cry:
We actualy gave up with the mot 3/4 of the way through ! bounus i did nt have to pay, The garage took pity on me !
Mot fails include
steering rack excessive play both sides. :cry:
both handbarake cables
both drop links
Rear radius bearing ( might be able to get an adviceryut need doing )
rear discs & pads
Other odds and sods
I would have fixed the car if it was nt for the steering rack !
What do you all think ?
Anyone know af another xantia 110bhp for sale cheap ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
andmcit
x 30
Re: The end is here from Xantia
Unread post by andmcit »
The rack isn't a horrible job - I'd sooner do that than a heater matrix!
What would you spend getting another that may not be as good as an
Exclusive spec? http://www.ebay.co.uk/itm/1999-CITROEN- ... 3a76af21f5" onclick="window.open(this.href);return false;
BTW, It IS a 110 - I've checked! Better the devil you know.
Nothing moves you like a Citroën
Deanxm
x 87
Unread post by Deanxm »
There is a guy who wants to sell one, passes very close to you too and its in great mechanical condition.
He may post up in a minute.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
imperial21
I have done the heater matrix already and i thought it was relatively easy !
I guess i should say the rack and rear suspension worry me the most !
If i new more about whats involved i could change my mind i suppose but also i need a good rack ! and cheap !!!!!!!!!!!!
lurchy666
Unread post by lurchy666 »
steering rack ends arent too bad to do and it aint the whole rack you do it from the wheel arches (or thats how i did mine) , basically they unsrew with a set of decent waterpump pliers or a set of stilsons(do a search and there is a thread on here somewhere how to do them) ,
when i did mine i found a website called livingston auto spares( google it ) you put your reg in and then find the steering section and search for the part called rack end, (make sure you get the right one as the later xantias had bigger ones), the ones i ordered for my hdi 110 was FTR4748 thats the part number on http://www.livingstonautoparts.co.uk/" onclick="window.open(this.href);return false;
drop links are 2 bolts each side again some are diffrent than others (plenty of advice on here how to do them im sure) also your best to get citroen ones or ( i cant remember the name of them now begins with a l and sounds german) but the cheap ones on ebay fail quite quickly,
brakes and pads i dont know as i havent done them on a xantia,
personally id do it up and keep it
c5 2.2 auto hdi estate 52 reg
andmcit
x 30
Does really depend on whether the play found is on the inner knuckle of
the track rods or the rack and pinion itself. Is it actually the inner or the
outer as the track rod ends will give excessive play although a decent MOT
guy should be specific with you especially if he knows you do the spannering.
Lemforder for the drop links?
It wasn't that long ago I bought a brand new rack on ebay for £15 and it was local
so I picked it up on the way home from the Ford (??? eh???) main steeler! Just got
to look thoroughly on ebay as you'll get what you're after - after all, everyone
probably feels the same about a rack change as you do so demand will be modest?
I've never seen the rear arms go on a Xantia yet but if it's the same as the Xm, CX,
GS/A it's only awkward undoing the piston on the arm itself.
lurchy666
andmcit wrote:Does really depend on whether the play found is on the inner knuckle of
if its the rack ends heres the how to http://www.frenchcarforum.co.uk/forum/v ... to#p312060" onclick="window.open(this.href);return false;
yeah there the ones
imperial21
I would change the rack by choice as on lock the steering makes some awful noises, He say s inner arm has play. Looking on ebay the rack is cheap enough. Can they be changed with the engine in situ ?
I do tow often with my car which will help to wear the suspension.
I am not worried about handbrake cables, drop links, rear discs i planed to do one day as calipers have corroded and taken the old pads and discs out.
andmcit
x 30
The only item that needs removal is the OSF lower wishbone and drop link
(the link just to make it really straightforward and you're changing it anyhow!)
http://www.frenchcarforum.co.uk/forum/v ... =3&t=34092" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... =3&t=35538" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... =3&t=35605" onclick="window.open(this.href);return false;
There's NO engine or subframe jiggery pokery whatsoever!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I suggest unclipping the front dogbone also, and loosening the ARB clamp bolts on the nearside. This simplifies getting stuff out the way.
imperial21
Looks like the Xantias day are numbered, I have had to visit the bank of mum and dad, so i can buy a C5 on ebay. I hope its the right thing to do and for once its as good as described !!
So i think i will be breaking my Xantia
Deanxm
x 87
I hope your getting a good interest rate :lol:
If you dont want to go digging too deep into your xant then yes you cant go far wrong with a c5, they are nice cars as im sure you now know and if its a good one it should give years of fairly trouble free service, do you have a lexia?
D
XM Prestige PRV6 92
imperial21
Hi dean
I have not got round to investing a lexia, Yet ! I will only consider 2hdi 8v, Keep things simple !
andmcit
x 30
So is it for sale then as I fancy a HDi Exclusive? Is it a saloon or an estate?? Colour, miles?
imperial21
Car will be for sale its actualy a good car, every thing works including the heated seats ! its a saloon in boring silver ! 123k miles serviced every 6500 miles, had clutch replaced 2 years ago but is juddery , spheres replaced on back, cambelt and pump changed, heater matrix replaced, etc
