Citroen C5 1.6 HDI
floggmolly
Citroen C5 1.6 HDI
Unread post by floggmolly »
I Put A Brand New Turbo On My 05 C5 1.6 Hdi. EGR Gone PTF Gone , When I Leave It Ticking Over It Is Making A Hunting Noise. There Is Also Something Flapping Inside I Think The Flapping Is Coming From The Throttle Body Unit. There Is Two Sensors On The Unit. One With A Brown Connection And One With A Yellow Connection. The One With The Brown Connection Is For The Big Flap In The Throttle Body Unit. If This Sensor Was Broke Would It Cause The Flap To Flap? And Would This Also Cause The Hunting Noise? Help Please!!
SaabC5
Re: Citroën C5 1.6 HDI
Unread post by SaabC5 »
If the engine is hunting its usually an indication of an air leak in the system. Check all the rubber hoses for tears/splits, you can also spray them with a soapy solution and look for air bubbles for pinholes you might have missed.
floggmolly
It only does the hunting when i start it when its cold..after a drive it clears
