Could anyone advise as to what exactly the strange 'spicy smell' is coming from the heater on my '98 2.1 TD Xantia. It seems to do it with either the heater on or the climate control.
Is it possible to get rid of this strange smell and is it just a case of having the air con serviced?
I have seen previous threads about this but not sure there was anything definitive.
Any thoughts much appreciated as winter looms!
By the way I have changed the pollen filter within the last thousand miles.
Spicy smell from Heater and Air Con.!!!
- x 1056
first check that the pollen filter is clean.there are aeresol sprays availible that clean out & kill bacteria in the A/C systems (i know FORTE make them).you just shut all the windows &remove the pollen filter, set the air to re-circulate & put the fans on full,place the can in the footwell & release it (the nozzle stays locked open).it will spray for a few minutes,it gets right through the whole system. had a quick look & couldnt find it (in english),i think this is dutch http://www.forte-nwe.com/NL/producten/a ... ioner.html
jeremy
Re-chargeing is only necessary when some of the refrigerant had leaked out (which can be by osmosis over the years) the refrigerant won't produce a smell as its long gone by the time your nose gets anywhere near (even if it has a smell)
Air con uses a condenser to dry the air and naturally this collects the water vapour which normally falls onto the road or if you are unlucky onto your feet. Eventually this condenser and other parts collect muck, and can form an ideal home for bacteria. If you get the unfriendly type they smell.
jeremy
jeremy
bxbodger
nick
