Xantia 1.9TD coolant spare tank
JohnCKL
Unread post by JohnCKL »
Hi, I want to order a new coolant spare tank for my 1996 Xantia 1.9 TD but I want the newer one with the cut out hole for the sensor which my original car don't have but I have installed the sensor myself by cutting out the hole. My spare tank was cracked on the bottom. Problem is, have to order according to the chassis number but I don't want to use my chassis number cos the original one do not have the sensor hole cut out. I need someone with a newer model of Xantia 1.9TD, maybe 1998 or 2000 with the sensor in the coolant spare tank. I need that chassis number so I can order that coolant spare tank with the sensor hole cut out. Also need to check that the bottom have 1 big and 1 small pipe. Some version have no small pipe and some have 2 small pipes. Anyone can help out. Thanks.
Xantia 1.9TD 1996
