C5 CD Multichanger
Bladerunner2125
C5 CD Multichanger
Have just bought my first Ctroen C5 2005 hdi VTR I can see the space and bracket for the CD Multichanger under the drivers seat also the wiring seem to be there for the CD Changer, what model of Changer do I need and also do I need the audio connection cable from Changer to Head unit? is the changer MP3 Compatible? and is this all plug and play or will I need to have the thing enabled by someone with a Lexia?
Citroen C5 MKII 2005 138 HDi VTR
waynedance
- x 8
Re: C5 CD Multichanger
http://www.ebay.co.uk/itm/CITROEN-C5-04 ... 27bbd668a2" onclick="window.open(this.href);return false;
Does this help as what model is needed?
Volvo S80 D5.........
Bladerunner2125
Very expensive for a secondhand changer, I notice the seller mentions code not included but might be needed, are the C5 changers coded?
Citroenmad
- x 110
I thought it would be as simple as that for my 56 C5 VTR too. So I bought the CD changer which fits into the cage under the drivers seat, I plugged in the wire which you will find under there and knew it needed a Lexia session to allow the car to see it had a CD changer. I did all of that and it still didn't work
Turns out while they go to the bother of putting in the CD changer cage and the wire from the back of the changer, that wire doesnt actually go beyond the carpet! There is no wire into the back of the radio from that CD changer wire
Having removed the radio to find this out, I saw th eammount of wires and other bits and pieces for the cliamte control and the general lack of any room and though better about fitting the wire. The CD changer is still under the seat, but im going to take it out and not wire it in. Im going to get, as some point, a X-car-link to allow me to play MP3s etc instead. Still means threading a wire through and into the dash but it will be of more use.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Bladerunner2125
Citroenmad this Xcarlink device does this require a Lexia session also? and how does it funtion with the head unit in the C5 VTR can you use folders for your MP3's or are they just in one long list? the head unit in my 2005 E-Class Merc only shows the MP3's on the CD in list form 1 to 99 per CD, no text or track names.Citroenmad wrote:I thought it would be as simple as that for my 56 C5 VTR too. So I bought the CD changer which fits into the cage under the drivers seat, I plugged in the wire which you will find under there and knew it needed a Lexia session to allow the car to see it had a CD changer. I did all of that and it still didn't work![]()
Turns out while they go to the bother of putting in the CD changer cage and the wire from the back of the changer, that wire doesnt actually go beyond the carpet! There is no wire into the back of the radio from that CD changer wire![]()
Citroenmad
- x 110
I dont think id does require a Lexia session no. I put a connects2 into my first C5 which didn't need one.
As far as I know the better X-car links you can operate the mp3 player or ipod from the radio controls. Im not sure if it displays the tracks on the cars display, possibly.
At the moment there is no provision for such use, and having an ipod in the car is of much more use to me than the CD changer. It is either or too as the link plugs into the CD changer port.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Bladerunner2125
Citromad thanks for the info thats a really helpful post, I will ask the question to some of the ebay sellers of the Xcarlink and see if folders and lists are available through the C5 Head unit, I really do not want to spend money on a Lexia just yet maybe later if the C5 proves reliable?Citroenmad wrote:I dont think id does require a Lexia session no. I put a connects2 into my first C5 which didn't need one.
Bladerunner2125
Actually I have dumped the whole Idea of a CD Changer and gone for an MP3 FM Transmitter off ebay £9 delivered plugs into the lighter socket and tunes into the FM Radio, no need for all this Lexia mumbo jumbo.
