Apart from Oil, filters and levels what else should I check before a long trip in a C5 Hdi 110?
Anything mechanical.
Apart from Oil, filters and levels what else?
boristhespie
- x 4
C'est pas possible!
Citroenmad
- x 110
Re: Apart from Oil, filters and levels what else?
Check that the brakes are not binging and the handbrake levers on the front calipers are not sticking. Its far from unknown and on a long journey is where you will notice it. So spin all 4 wheels and make sure they are free running.
Obvioulsly check tyres, condition and pressure. If its a long motorway run and even more so if their is weight in the car, go for the higher loaded pressures.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
andmcit
- x 30
I was about to say tyres and their pressures! How about making sure you have the kit you need to swap to the spare if you get a puncture a long way from home rather than rely on the AA man!? Not just a decent spare or jack but a decent wheel brace. For my sins I had to get a trailer and tow car Relayed home as the fancy after market alloy wheel bolts were too short to secure the spare steel wheel even though I had my full toolkit and 3.5 tonne trolley jack on the boot!
Then there's decent wipers that don't judder and concentrate screen wash as you're relying a whole lot more on good visibility for anticipating the road ahead whilst at high motorway speeds and knowing our ropey summer weather: last thing you need is a smeary fly splattered screen and distractions from duff wipers!
Then there's a decent scale hard copy atlas in the seat pocket as all crapnav jobbies are only good for leading you around the houses to see the bleedin steeple!
Nothing moves you like a Citroën
boristhespie
- x 4
Do. Need to chexk anything re the wheels like bushes etc?
C'est pas possible!
- x 8425
Weekly and before any long journey I always check all fluid levels and have a good look around and underneath for anything loose, leaks, the integrity of the driveshaft boots and exhaust and generally for anything that looks not quite right.
I look at all four brake discs to ensure they're all nice and shiny. 'Bluing' of a disc surface can indicate binding - the colouration coming from the heat generated. When stopping during a long trip I'll also feel the wheels in turn making sure they're reasonably cool..
Tyres - goes without saying really. Condition and pressure.
boristhespie
- x 4
reblack68
I think he meant binding.
Richard
Care of a 1994 205 D.
boristhespie
- x 4
So oil change. I provided. Fuel, Air, oil and pollen filters with a once over £106. Not unhappy.
C'est pas possible!
