ZX Blower failure
froggy
- (Donor 2026)
- x 4
ZX Blower failure
Hi, the blower in my 1995 ZX has just stopped working . I have checked the fuse, it/s ok . I changed the resistor pack last year, so hopefully that/s ok . Iam wondering, could it be the switch ( dashboard) or maybe the motor itself . If so, how can I test both items? Thanks inadvance Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Lighty
- x 34
Re: ZX Blower failure
I bet it's the blower resistor again, they fail regularly, my theory is that when the motor gets old and tight, it pops them frequently.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Sl4yer
Yes, did on my old 1.4. A replacement from the scrapper sorted it out. although they're all getting old now. Easier than continuously replacing resistor packs.Lighty wrote:I bet it's the blower resistor again, they fail regularly, my theory is that when the motor gets old and tight, it pops them frequently.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
froggy
- (Donor 2026)
- x 4
Just replaced the resistor pack on my ZX. Started up.......then a pop noise!! I thought the resistor packs gone . the blower starts again , miracle, then the blower starts sqeaking, well, could the problem be the motor itself ? and not the resistor . any thoughts? cheers inadvance, Terry .
Terry
froggy
- (Donor 2026)
- x 4
The new Resistor pack, lasted all of one day ! Again no blower ! Should I be looking to replace the Valeo motor? thanks in advance Terry .
Terry
Sl4yer
Hi Terry. As Lighty stated, and as happened with mine, the blower gets tight and blows the resistors. Time for a replacement blower.
It's an easy DIY job if you can get one.
2008 Mazda RX-8 231
