automatic gear zx2.0i
imrover63
Unread post by imrover63 »
the automatic transmission of my zx2.0i seems to lock into neutral while driving, it has happened twice this week. Any inputs on the possible causes.
thank you.
alan s
RIP 2010
x 6
Unread post by alan s »
By "lock into neutral" I presume you mean it loses all power as though it's in neutral (ie) motor revs but car is not being pushed along by it........If this is the case, check the level of your auto transmission fluid.
In case you're unaware, this must be tested with the engine running & in neutral. If this checks out OK, then next would be to check engine & gearbox mounts & linkages.
Alan S
imrover63
thank you
