dtr starting issues
ella
dtr starting issues
Unread post by ella »
few weeks ago Ella fired up as normal,the died as if out of fuel,had changed the fuel filter recently so assumed this was the problem,after bleeding the system she would eventually fire up then run as normal,but next day it would be the same proceedure all over again,as the fuel primer pump seemed a tad iffy(not always pumping) i changed this yesterday,bled the fuel through and took her for a short run,this morning tried her again,back to the same symptoms(almost firing) bought some easy start and hey voila she fired up. before i pull the glo plugs to check them,wondered if you guys could shed some light on this problem??? #-o
CGATCX25GTITURBO
x 16
Re: dtr starting issues
Unread post by CGATCX25GTITURBO »
if this srill has the fuel heater on the side of the cylinder head... loop it out of the system, these go porous!
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
