1. i changed the rear trailing arm bearings .no problem
2.i noticed the rear was fluctuating before it settled,done all the usual.ie.jumping on towbar citrobotics ect.still a small problem.
3.took it to an auto electrician to be reset with a lexia to get a call off him saying he cant do.same problem
4.got car back,and now have a car that has now got all suspension warning lights on the dash and i cant manually lower or raise height via centre console.big problem.
5.lexia reads error code p3551 broken wire or bad earth .it didnt have this problem before .big problem
6.i have also replaced rear height sensor to no avail
any ideas and help on how to cure would be really appreciated.thanks for looking
c5 estate suspesion [yet again]
Re: c5 estate suspesion [yet again]
Check the rear hieght adjuster for siezing or try disconecting it
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
I want to do this job (the bearing change that is) on mine soon, so I'm intrigued. The height adjusters aren't just mechanical devices like on the Xantia are they? They're pots, so could it not just be that one of those wires did take a hit during the work?
Next step would be to locate the wires back to check it, but I reckon you've already looked - weather being well I want to make a start in mine tom afternoon / weekend and I could take a look see if could take some readings too. I want to get my Lexia working again as well, whereabouts are you, I'm near Luton.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
sunny north wales
ah, bit of a run then.... Good job there's a forum!
- x 9
Can you hear the pump running when you select high? if not it is probably the 40A fuse that feeds the motor, they take a bit of a caning if lots of suspension changes are made in a short space of time.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
yes pump runs fine.cant clear warning lights on dash either..
had new sensors front and back.can manually adjust rear ,middle sitch on centre console still no power.
can anyone tell me if the middle switch [centre console]has its own power is is it powered through an earth,thanks
