brakes
alexx
AndersDK
Dave Burns
- x 3
If you have the back end jacked up and wheels off the ground with the ride height set to normal, there will be no pressure in the rear brake circuit, you must as Anders says have the suspension on the high setting if the rear wheels are off the ground.
The reason is as Alexx has said, rear brakes get their pressure feed from the rear suspension circuit, this enables the rear brakes to be load sensetive.
Dave
Dave
alexx
