BSI code
Trainman
(Donor 2018)
x 43
BSI code
Unread post by Trainman »
Guy's using the Lexia today, I wanted to change the settings in the radio, when I went to do it, Lexia tells me the radio BSI needs a number........any ideas where I can find it?
Steve
http://c6owners.org/index.php
The Birdman
Re: BSI code
Unread post by The Birdman »
What settings you want to change?
You mean Radio ECU ?
Try 03114 customer code.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
Trainman
(Donor 2018)
x 43
Re: BSI code
A lot of stuff on the C6 is controlled through the head unit, for example th day time running lights or the retraction of the sterring wheel when the engine is turned off.
I will give it a try. Thanks
Steve
