Remote central locking on one door
Welshy_Pete
Unread post by Welshy_Pete »
The remote central locking works fine sometimes then other times like now wont. The 2 rear doors and passanger front door go down the catch. But the driver side wont sometimes and have to use the key then remote.
Is the central locking motor the problem or anything else?
306 hdi
thanks
spider
x 77
Re: Remote central locking on one door
Unread post by spider »
Might just be the actuator microswitch at fault if its intermittent. The clue here is the fact it works if you use the other method of locking / unlocking it, ie: remote or key. I'd go for an actuator as a first step if you can get one cheaply. My 106 does this, it works fine with the remote but you have to unlock / lock about 10 times with the key to make it 'respond'.
My first thought was the door loom ( :( ) which is quite common and surprisingly annoying to repair.
Andy.
