Radio fitting
Robbie
Radio fitting
Unread post by Robbie »
If I buy a new cd/radio player (PANASONIC CQ HX1003)
for my Xantia 98td will it plug straight in to the existing connectors (not the steering wheel just power and speakers) I also know I need a facia plate, it's just the power connector and speaker connector I'm not sure about?
Robbie
x 1060
Unread post by wheeler »
the xantia has ISO plugs which means it should just plug straight into most modern radios.some models of radio will require the battery & ignition feeds to be swapped around but there is usually a method of doing this with the connector with the radio.check the radios spec to see if it has ISO.
