Xantia Key
mckenzig
Xantia Key
I have recently bought two plain keys with the chip in them. If I start the car with our existing key, take it out and replace it with one of the new ones, the car will start. Leave it for a few minutes and it wont start. The new keys will open the doors though. Any one got any thoughts on what programming I have too do?
addo
- Sara Watson's Stalker
- x 95
evilclive
- x 3
Re: Xantia Key
Yes, they do that. Surprised me too. Makes it a bit tedious checking if you've successfully programmed the thing.
You need a lexia/lexia clone and the 4 digit code to program it. It's pretty easy.
- x 1056
Re: Xantia Key
Thats normal operation, if you dont open any doors after you take the key out the imobiliser takes a few minutes to arm itself, if you open a door it arms a lot faster.mckenzig wrote:If I start the car with our existing key, take it out and replace it with one of the new ones, the car will start. Leave it for a few minutes and it wont start.
As alreay said you need Lexia or some other key programing software/equipment & also the 4 digit security code.
