Leaks from the front anti sink valve are common. It can be repaired with an O-ring designed for the pump, info in this thread: anti sink valve repair
Possibly worth changing when the LHM tank is out for LHM change, as preventative maintenance!
Xantia anti sink valve leak
- x 1498
