Hi All,
The on / off / volume knob on the standard radio has begun to stick. Having failed to get the fascia off I managed to pull the knob out of its hole. Without the knob the switch seems fine. The tube inside the knob has a couple of splits in it and it looks like this is the cause of the sticking.
Questions:
Am I likely to be able to get a replacement knob from Citroen?
or from a radio specialist?
The knob seems to be flared at the end which goes into the radio - is this normal?
If I can get a new knob, will I be able to simply press it in as I pulled it out or will I have to get the unit out of the fascia to do this?
Finally what tool will I need to remove the radio? The BOL says a torx screwdriver but not what size. My smallest one, bought for mobile phone repair, doesn't fit.
C5 II Radio issues
Philjw
C5 II Radio issues
Phil
05 C5 Estate 2.0 16v + 05 C4 Hatchback 2.0 16V
The Birdman
Re: C5 II Radio issues
Put a little bit of paper in it , should be fine
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
- x 1060
A modified button is available from Citroen part number 6564 P3. It's just a push on job, no need to remove the radio.
Philjw
Thanks for the replies. My nearest Peugeot dealer has the part in stock for around £1.00. The part number has changed to 6564QS. Let's hope it fits.
Phil
