Good Day to you all.
Right just need some advice on the way home from whilst gently driving around the wazza roundabout i heard a snap...then no steering, no air con no bloody cold air at all....had to fight the steering all the way home 5 minute drive....once i arrived home after screaming expletives to the mrs and kids i popped open the bonnet to find a belt had snapped...it's the one that goes around the alternator....my questions is this.
1 What is this belt.
2 How much to repair.
3 is it an easy job.
The car in question is a Xantia HDi 90 Forte year 2000.
Any Help much appreciated.
s**t Happens
Monkee-Mike
Re: (-expletive removed-) Happens
Is it the Drive Belt Part Number 6PK1740?
- x 8455
1. Auxiliary belt. Drives the alternator, hydraulic Pump and aircon compressor.
2. Depends. On an HDi you may just be lucky that it was a tired belt. However, you were bloody lucky it's didn't flail around and take the cambelt out too...
Before replacing it check the tensioners and the crank pulley. Either the crank pulley (a dual-mass affair) may have failed or one or the other of the tensioners may have failed. One's a spring-loaded automatic job and the other is a static eccentric tensioner. Did you hear any clonking prior to this that might suggest the crank pulley is looking for an alternative lifestyle in the bin? Red dusty rust on it is a clue.
3. yes, actually it is - fairly. Remove the RH mudshield protecting that side of the engine and the belt. Release the spring-loaded tensioner using a 15mm spanner on the centre hex, pin the tensioner back in its off position and slip on the new belt. Release the tensioner. Run the engine and check the new belt is running absolutely true on all pulleys and that tensioners are not cocked over to one side. Listen for any clonks from the crank pulley when starting or stopping engine and look for the powdery rust on it as a clue. If in doubt replace.
Also, inspect the cambelt covers for signs of damage. If you find any the cambelt covers MUST come off for inspection and potential replacement of the cambelt too...
I've painted a grim picture there. I expect and hope it's just a simple failure...
Isn't the steering heavy though, with no power assistance!
Monkee-Mike
Citro Jim your a knight in shinning armour.
Just been out to check around the pulleys and tensioners all seem fine no sign of the red dust no loose cams. Cambelt cover looks in tact.
No Clonking noise prior just the sound of an elastic band snapping.
steering wasnt that bad before could fling round corners but once this had happened i was practically swinging on the steering wheel both arms and feet lol. i had to manouver two more roundabouts it looked like from the outside world i was driving an articulated lorry with how wide the car was swinging round the corners.
- x 8455
That's good news
As for belt size Mike, it depends on your aircon compressor:
Sanden: 6PK1736 (a 6PK1740 should be fine)
Delph or Hutchinson: 6PK1750
Monkee-Mike
Just been on eurocarparts and they have recommended the 6PK1740 £21.50.. For my model continental too i thought they only do tyres.
Well hope this weather keeps cos i know what im doing this weekend lol...
Thanks Jim for the Top Advice much appreciated
evilclive
- x 3
Don't you lose brakes and suspension too?Monkee-Mike wrote:Citro Jim your a knight in shinning armour.
DickieG
- Monaco's youngest playboy
- x 33
Steering first then suspension followed eventually by brakes as pressure subsides.evilclive wrote:Don't you lose brakes and suspension too?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Jaf
- x 42
I turned the engine off once going downhill to see what happened. Eek never again. Felt like no steering and no brakes to me rather than suspension but I didn't wait very long before turning the engine back on!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
Xaccers
- x 188
If you have no brakes when your engine isn't running then it's way past time to replace your accumulator sphere! (and anti-sink sphere)Jaf wrote:I turned the engine off once going downhill to see what happened. Eek never again. Felt like no steering and no brakes to me rather than suspension but I didn't wait very long before turning the engine back on!
DIY sphere tool
DIY sphere tool
