Xantia HDi 110 turbo outlet pipe bolt fixing type ?
HDI
x 7
Unread post by HDI »
Just got hold of a replacement turbo outlet pipe to replace the one on mine which had a broken fixing bracket. It bolts to the bell housing just before where it connects to the intercooler inlet. The original bolt is long gone but looking at the rubber bush in the pipe and the locating hole in the bell housing I'm assuming it must be some type of special bolt or locating spindle. Can anyone help with an illustration to show what should be there please ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1502
Re: Xantia HDi 110 turbo outlet pipe bolt fixing type ?
Service.citroen says:
6922 76
RP 6922 F0
01 SELF-TAP SCREWS
DIAM 8X125-30
Then
0382 K1
01 WIRING SHEATH
DIAM 14
Then the pipe, then
96 135 635
NFP
STEEL SPACER
8,5 X 22 EP 9,5
HDI
x 7
Thanks Richard. Doesn't make sense though ! Especially the self tappers bit !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1502
It's just an M8 bolt, 30mm long, 1.25mm pitch, usually with a chamfered end to make it 'self tapping' - it could have a cut out in end I suppose, sometimes they do. I doubt the bits will be dear if you apply at your local dealer.... :lol:
HDI
x 7
Understood but I stiil don't see how those parts correlate to the location the pipe attaches to. I need to see a diagram really.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1502
PM me your e-mail and I'll send it over.
