Additive Low Level Sensor Fault
Suffolkpete
Unread post by Suffolkpete »
I've had the minimum level fault come up on my 2002 C5 2.2HDi. I've topped up the tank (DPX42) and reset the ECU, I've got a Lexia, but still the fault persists as a permanent fault (P1435). Is the sensor faulty or is it the ECU? The parts list on Citroen Service doesn't show a sensor, although I suspect that is is described there as a harness, like the fuel cap sensor. What do the experts think?
Lighty
x 34
Re: Additive Low Level Sensor Fault
Unread post by Lighty »
The sensor is built into the Eolys tank, and can't be removed, sometimes they will reset after a week or so with fluid in.
Otherwise it's a new tank,methinks they are about £200
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Suffolkpete
I've checked the continuity of the connections between the ECU and the additive tank and all are ok, but when I try to measure the resistance between pins 1 & 2 (level sensor connections) on the additive tank, it shows an open circuit which leads me to suspect that the sensor is faulty. £200 just to remove an error message is a bit excessive so my question is: given that the sensor is a thermistor, can I replace it with a resistor to fool the ECU into thinking that the level is ok? If so what value? I can't see anything wrong with this, I believe that later cars don't have a sensor anyway and I will still get an alarm when the "Ash in filter" limit is reached.
x 8455
How does a thermistor measure a fluid level? Is there a marked temperature difference between it being submerged in the Eolys fluid and in the open air?
Suffolkpete
Yes, I believe that's the theory, I have a similar arrangement for the oil level sensor on my Matra.
