ABS finally fixed it
merlin22red
it's taken me ages, mainly due to time constraints but me ABS is fixed, but i still can't understand why someone would want to cut the wires in the harness, maybe some weird reasoning any how the owd shed is working again and will not be retired to the back yard to keep chickins in
samson1886
Re: ABS finally fixed it
Mine (ZX) ABS is having fault either. The warning lights lit permanently from the moment the key is inserted & switch to ignition, enginer start. The light won't go off unless otherwise I switch of the key.
It didn't flashing either. Just permanently on...
Someone told me there are no power supply to ABS ECU. There is also possibility the ABS Pump spoilt.
Having said so, I think I need to ensure there are power supply to ABS ECU, and get it connected via Lexia3 in order to investigate if there are any fault further.
The problem how should I identified which wires identified as what?
Are you having the same issues as i am?
merlin22red
No mine was a fault on the sensor but even after fitting a new one the fault was still there or so my mates lexia said, I then found a cut wire a little way up the harness above the sensor plug
