Xantia Front Wheel Bearing
x 1438
Unread post by xantia_v6 »
One of my front wheel bearing has been grumbling for a while, but has been getting more noticeable this week, maybe since I replaced the suspension arm bushes, the new bushes are stiffer and transmitting the noise more effectively.
It seems loudest at 50MPH but is quiet on a RH bend. But which one is it :?:
RichardW wrote:"if it is a wheel bearing, the noise will get louder when the weight is thrown on to the side with the faulty one."
Since this a Xantia, not always! I had one go that I was convinced was the N/S/F, based on the above. But when I took it to the gargae, it turned out to be the O/S/F - ie it went quiet when loaded. :twisted: Got to love these Xantias 8) Incidentally that was only noisy above 30 mph,
x 8289
Re: Xantia Front Wheel Bearing
Mike, if one's on the way out than both will be. Swap both...
My press awaits :wink: Get in touch to make an appointment. Sadly not next weekend though...
x 94
Unread post by citronut »
jack one wheel off the graund whilst on normal suspension height,
choke the rear wheels, let the hand brake off and stick it in second gear with the engine running, you should be able to determine which side has gone after trying both one side at a time though,
if you can't work it out doing this, the only sure way is remove front pads and drive shaft from each hub, then you will feel the one with bearing on its way out,
regards malcolm
HDI
x 7
Unread post by HDI »
I've always done this on a 2 post lift, so obviously both wheels are free, so you could use a trolley jack and lift the front of the car for convenience, instead of one at a time.
7 times out of 10 it's the other to the one you think it is !
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
VertVega
x 13
Unread post by VertVega »
xantia_v6 wrote: ... It seems loudest at 50MPH but is quiet on a RH bend. But which one is it :?: ...
Usually when the wheel is under load (while bend), the defective wheel bearing becomes louder :) but this is not a rule. In mine front left behaved like that and now front right is doing the same and I have already booked next Wednesday for replacement. I think it has served very well, considering that clock shows over 230 :roll: =D> and it's still original factory assembly.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
citronut wrote:jack one wheel off the graund whilst on normal suspension height,
Bugger that :shock: despite the differential you're a braver man than me Malcolm.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8289
Bugger that seconded :)
x 94
HDI wrote:I've always done this on a 2 post lift, so obviously both wheels are free, so you could use a trolley jack and lift the front of the car for convenience, instead of one at a time.
the reason its the other 7 times out of 10 is you are spinning both wheel up together,
the idea that i use with 99% success is im spinning one wheel at a time under controlled condition's,
whilst sitting in the car, not to much RPM and the other wheel firmly on the ground,
this way you will almost every time hear the noisy bearing,
POO POO
the way the diff works the wheel of the ground spins and the one on the ground does not,
imagine having one drive wheel in a muddy ditch and the other on a solid surface, the car wont go anywhere as the wheel in the mud will just spin,
although i do agree this test has to be done with all/any dangers in mind, and as long as the lifted wheel does not touch the ground there should not be any problems ,
i would not use this method on a 4X4 :shock: :-D :twisted:
regards malcolm
regards malcolm
DickieG
x 38
I fully understand how a differential works but even then the static wheel will be attempting to pull the car off of it's supports, I might have considered this if the handbrake worked on the back wheels but on a Xantia, no thanks, I'll leave this idea for you.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
HDI
x 7
regards malcolm
What I meant was the the one you think it is when driving the car. The faulty bearing is immediately obvious with both wheels driven on a lift or jacked up.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 94
i personally don't find you can determine for sure with both front wheels off the ground and spinning,
regards malcolm
HDI
x 7
It is probably more easily identified in the air on a lift. Literally you can go to each side and the offending bearing just leaps out at you :wink:
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
