My N/S/F brake caliper is leaking from behind the rubber boot.
I've found a rebuild kit on EBay that will fit the 'Standard 60mm single piston Bosch caliper'.
Is this the one that I need?
Ta very much.
Steve.
Quick Xantia HDI 110 question
Stepto1
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
citroenxm
- Fallen Hero
- x 70
Re: Quick Xantia HDI 110 question
If it helps, the HDi 110 uses the SAME calipers as the V6 Xantia.. I beleve the Bosch Brakes used were the one size only on both models.
The Estates use larger brakes then the Standard hatch, but Im not familliar with them. I do beleve they are different again, but not as big as HDi/V6 sorts.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
