Peugeot 206 2004 1.4HDi front fog light installation!
avamotor
(Donor 2022)
Unread post by avamotor »
Hello FCF members,
General enquiry for those that have braved or know how to go about "retro" fitting front foglights. :)
Right I understand my car is fully multiplexed as its 2004 (june 2004 i think), a curious glance to the back of the front bumper has revealed both the cut out markers for standard foglight installation and the wiring plugs and associated wires appear to be in place or at least thats what I belive there for (i think). :shock:
The bit that confused me was, in a different post accross the internet somewhere, it was claimed that if your engine bay fuse box is currently BSM B2 you would need to upgrade to a BSM B3 that had the facility to allow a fuse for the front fogs and obviously get the combined stalk for indicator/wipers/lights/audio stereo stalk that also had the front fog logo as well as the rear logo in order to allow the fogs to work (including switching on in planet peugeot 2000). :?
Having removed the cover on my engine fuse box I have found that my fuse box is a BSM B4 that already has fuse 6 in place! would I be right in thinking I have a suitable fusebox in place already and just need to source a combined stalk for indicator/wipers/lights/audio stereo stalk that also had the front fog logo as well as the rear logo and i'm up and running???
Thank you in advance.
Garry.
spider
x 77
Re: Peugeot 206 2004 1.4HDi front fog light installation!
Unread post by spider »
I think that might be it, you may need to stick it on Planet to tell it about the front fogs etc as you mentioned.
If you wanted to 'test' it first if possible obtain a switch and then just see if you get anything from the front end connector (before buying the expensive bit, ie the lights themselves) , possibly add a fuse under the bonnet fusebox too.
I seem to remember something about the models being differentiated between "factory fogs" and "accessory fogs" but that might be non-plexed models.
Andy.
x 1044
Unread post by wheeler »
The only difference between the lighting on stalk on models with & without front fogs is the logo, the electrical part is the same. I've fitted accessory kits to citroen C2 & C3's & the kit comes with a little sticker to put on the stalk to show it has front fogs.
Yes you will also need to enable them with planet.
