Got into the expert this evening and as soon as I touched the brakes I noticed that something was wrong. The pedal seems to need a lot of pressure to stop. At first I thought there must be a leak, split hose, but got out to check and no sign of any leaks. I then tested the brakes before carrying on to work and they still work great, but require a lot more pressure than usual. Kind of like there's no servo assistance, same as when being towed without the engine running.
It's a 1.9td with the XUd engine. I'm thinking maybe vac pump failure, sound likely? Not heard of one fail before, any ideas appreciated.
Expert brake problem
ohms
91 Citroen AX 1.4D
99 BMW M Coupe
99 BMW M Coupe
sean86
Re: Expert brake problem
did you check the vac hoses for leaks?
02 xsara 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
Oldpug
- x 94
If you have a "Hard" pedal with no travel the servo is not working correctly.As said first check for leaks,follow the vac`pipe from the servo to the vac` pump which fits on the end of the cylinder head and is driven by the camshaft.Some models have a small "T" piece as well with an extra small vac` pipe that supplies something else??.Make sure all these are in good condition with no leaks.The favorite cause of a split vac` pipe on Pug diesels is the plastic engine cover (if fitted) braking its fittings and rubbing a hole in the pipe.If all is well with the pipes it will be the vac` pump.Simple test,remove pipe from pump,start engine,and "feel" for suction at the pump outlet. Very simple job to replace a pump,just make sure its located in the camshaft correctly and the "O" ring is also located before tightening.
