xantia 1.9td 1994
frigate
xantia 1.9td 1994
Unread post by frigate »
I`ve a kind of pulsating thru the Brake peddle when I brake lightly and when I leave the car it dos`nt lower to the rest position.any ideas
AndersDK
Unread post by AndersDK »
Definately air in suspension.
Try the Citaerobics :
Engine idle, select neutral, handbrake applied.
Set suspension height to max - then set to lowest.
Allow due time for car to settle on each new height setting.
Repeat 5 times.
