What's this thing under the bonnet of the estate?
Napoleon
x 4
Unread post by Napoleon »
You can pull the cap off this thing, and it looks like you can put a key in there, but what the heck for? It's located on the near side at the back of the engine bay.
DSC05425 by Tim Redberry, on Flickr
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
Xaccers
x 188
Re: What's this thing under the bonnet of the estate?
Unread post by Xaccers »
Disables the alarm siren.
DIY sphere tool
spider
x 77
Unread post by spider »
I concur, tis the alarm silencer. I don't think it kills the alarm just the noise. The lights will still flash etc.
I seem to remember the key is different so you may not have one, but no matter really. The Peugeots tend to have them at the front near the slam panel area opposed to near the bulkhead.
Andy.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
just to help spider its the same key as the ignition key.. most sirens have packed up on s1 cars.. well the ones ive had have never sounded when going off even after messing with that switch.
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
citroenxm wrote:just to help spider its the same key as the ignition key
that is if it aint had a replacement ignition lock at some point in its life,
regards malcolm
Xaccers
x 188
I have a feeling it's not key specific, so any key should do it.
DIY sphere tool
spider
x 77
I do remember the 306 ones had a different key to the normal key for the car, some early ones at least. Was easier to chop the wiring but as said the backup batteries have long since died in most cases.
Andy.
x 94
Xac wrote:I have a feeling it's not key specific, so any key should do it.
all the ones i have seen on XANT's have been the same key/cut as the ignition key,
regards malcolm
