c5 suspension leaking front left suspension
dudarus1
Unread post by dudarus1 »
in have just bought a c5 and ive notised that the suspension is leaking from the front left corner theres a flexipipe which goes ton the shock and when the suspension come all the way down it floods out of this pipe. is it a hard job to replace this pipe. also do i need to grease the shockers on this vehicle as they look abit rusty.
thanks in advance
Mobile Towbar Fitting Service In The Midlands
http://www.jninstallations.co.uk" onclick="window.open(this.href);return false;
Cheapest Prices Guaranteed
Jabo
Re: c5 suspension leaking front left suspension
Unread post by Jabo »
Your car doesn't have "shocks," I think you're talking about your struts and no, you don't need to grease them.
The hydraulic pipework isn't too difficult to work with if you have ramps or axle stands.
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
dudarus1
thanks for the reply ill have a go at changing the pipe. do i need brake pipe spanners to change the front flexi. also on the resevoir how do i know when theres enough fluid in it.
thank you
Jabo
These reservoirs don't have markings on them but as long as there's fluid in it when the suspension is at each of its different height settings then you've got enough. Personally I fill my reservoir to just above half way.
I haven't personally removed the flexi but I would imagine that you do need brake pipe spanners.
