On the ph3 306 hdi the alarm immobiliser how does it all work properly. I know I can lock the doors with the keys and get the dead lock working and lights flashing etc. Also the same with the fob buttons as well works fine to. The dash has the indicators flash up.
But what I wanted to know was where the red flashing led?
Also is there any sensors inside you can switch on and of etc?
Alarm immobiliser ph3 306
spider
- x 77
Re: Alarm immobiliser ph3 306
Not that I am aware of, maybe ultrasonics if it has them via the button on the steering column cowling although I seem to recall the later ones did not have this.
The 'warning' (if fitted) is a tiny 2mm led or so around the middle heater outlet vents.
Andy.
