406 drop links
x 1240
406 drop links
Unread post by Peter.N. »
I have just fitted my second n/s front drop link in about a year, its probably not covered more than 12,000 miles, the ball part seems quite good but the rubber boot has perished and let the water in, I notice the other side is going the same way although it hasn't started rattling yet, I poked some grease into it in a bid to make it last a bit longer. The the genuine ones are about five times the price of ebay replacements, do they last five times longer?
x 94
Re: 406 drop links
Unread post by citronut »
there are company's selling a selection pack of replacement swivel boots/dust covers, in this case it might be an idea to save some dosh,
i don't usually agree/belive in fitting replacement boots to swivel joints because if the boot is damaged it grit and dirt gets in, then fitting a new boot will just trap it all in,
regards malcolm
Lighty
x 34
Re: 406 drop links
Unread post by Lighty »
I think the cheap ones are generally made in china, and their rubber fails very quickly.
As Malc says a replacement boot may save money for a while, the lemforder links are o.e. quality, but only about twice the price of the rammel ones.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Oldpug
x 94
Re: 406 drop links
Unread post by Oldpug »
I`ve always used O/E quality ones from GSF or EURO, they seam to last well and are much cheaper than Dealer ones.
x 1240
Re: 406 drop links
I will check those. The ones I got were about a tenner for two, the only OE ones I have seen were about £30.00. I wonder if it would be worth fitting a better boot on a cheap new one, I always take mine off and fill them with grease anyway.
x 94
Re: 406 drop links
i personally don't trust ECP any more as i belive they are squeezing there buying in price down so far the quality :^o :wink: has got to suffer,
regards malcolm
