Finally fixed it.
MonkeyMark
Finally fixed it.
Unread post by MonkeyMark »
Well i knew water was getting into my drivers footwell, and guessed it would be fromt he rear washer pipe. I was correct.
I thought it must have split, but infact someone had done a rather bad job or connecting it (guess they took out a 1 way valve or something) with tape :shock:
The carpet was much much wetter than i had expected. It was pretty much swimming in the footwell and cable trays and had been for some time by the looks of it. One of the strut bars (if thats what they are called) under the dash had a lot of surface rust so that was cleaned and then treated.
Left the carpet up for two days and its dry now. The water had got as far back as the handbrake which caused the "handbrake on" light to come on randomly and the passenger airbag to swith on and off all the time. Both seem to have stopped now.
Time to move on to another couple of niggles.
Just thought id share my small success! 8-)
Happy(ish) C8 owner.
waynedance
x 8
Re: Finally fixed it.
Unread post by waynedance »
It's good when you trace a fault and fix it yourself, glad you got it sorted.
What car you got?
Volvo S80 D5.........
MonkeyMark
waynedance wrote:It's good when you trace a fault and fix it yourself, glad you got it sorted.
What car you got?
I have am 03 C8. Only had it a couple of month and just working my way through a couple of niggle's.
Need a drivers side door rubber and door catch.
Other than that it seems to be in great condition.
MonkeyMark
Ok, so I THOUGHT i'd fixed it!
The washer pipe is now fine, but upon inspection, the floor is soaking again.
I left it running for a while with air con on to see it that was leaking but it seamed fine.
The wetest part now seems to be around the hand brake lever.
I'm wondering if its coming in around the door seal or if the drains in the door (if it has them) could be blocked causing it to over flow inwards.
It seemed to be after we had some heavy rain.
Any known issues that could be causing this?
