In the style of injectors thats used in the XUD/TUD range (and a lot of others, VW etc). I know it's kind of not so technical, but I am sure you know the family I mean. The 'double eared' (two leak off pipe connections pressed directly into the top casing) injectors that are used in pretty much most Bosch-injected car engines of the period.
They all have pop-ratings printed on them, as well as the Bosch number of course, on the top casing, like 120bar or 130bar etc.
But, do I understand correctly, that this whole family of injectors has identical top cases, and it's the actual spring and shim that sets the pop pressure? So, different engine systems use different bottom casings (since they have different threads/collar nut sizes, and also some have nozzle shields), but the top casings are all identical?
So, in this picture:
-Part 7 is the nozzle, which come in different 'flavors', and I know a lot of people who mod diesels often change them for different sizes etc.
-Part 6 (the bottom casing) is engine-specific, because different companies heads have different threads etc
-Part 3 and 1 (spring and shim) are the ONLY parts that set the pop pressure
-Part 5 and 4 (I call them the anvil and hammer, although thats neither correct not accurate) are universal to that family of injectors.
Is this correct so far?
So, does that mean, that, for example, if I use the spring, shim and nozzle from a 120 bar injector, and then screw the top casings from a 130 bar injector into them, that it would in fact be a 120bar injector with '130 bar' printed on it?
In other words, the part that carries the pressure rating stamping (the top casing) actually has absolutely no role in setting the pressure?
The reason I ask is because I had some good XUD 120bar injectors, and I disassembled them and left the parts neatly arranged on a clean towel on the floor, and then my friend proceeded to neatly reverse his beetle right over the towel, which went over the top halves and snapped off all their return pipe stubs. The other parts were not run over tho.
I also have some similar injectors but rated at 130 bar, from some other engine, different thread to the XUDs. So can I just use the top casings from the 130 bar injectors, and the springs/shims/bottom casings/nozzles/etc from the 120 bar injectors, and they will still stay 120bar (despite the fact that they will confusingly say 130bar on them)?
PS I know that mix-and-matching used injector parts is never ideal, since they all wear differently etc in theory.
