Bonnet gas struts
Bonnet gas struts
HI, my son has a Peugeot 406 which has gas struts on the bonnet which makes it so easy to open, I wanted to know if I could fit these to my 2 series Xantia HDI because the bonnet weighs a ton, I was thinking they could be fitted useing Epoxy glue or something similar.
allanmc
allanmc
Xantia 2.0i SX Auto, 1999
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Bonnet gas struts
its such a shame the xantia never got struts... the lesser xsara got them.. they would have to fit between the bonnet under side and inner wing top edge.. im not sure how much clearence there is for them... i doubt epoxy would be strong enough.. the spigots would have to be welded or bolted in place.. theres some force in those struts.. as for fixing them plates may need to be added as theres not enough lip. . you dont want the epoxy giving when the bonnets up.. one strut is not enough to hold it up....!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- CitroJim
- x 6204
- Contact:
It's odd because as far as I know all Pugs of that era had them (306 certainly) and the XM did..
I believe the reason the XM had them and the Xantia didn't was the fact that it's rarely necessary to lift a Xantia bonnet
Unlike an XM...
<runs and hides>
Unlike an XM...
<runs and hides>
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Does seem to vary though.
As far as I know no Saxo's had them (not sure please clarify) but 106's all newer shape had them.
No 206's had them which was a shame although given the lightness of the bonnet not a problem but they are quite neat in a way generally, one less thing to do.
All newer shape 306's had them.
Some very early 406's did not (not many I think only a few N plates) but the bonnet was very heavy so I guess they had to. Surprising to learn the Xantia never had them.
I dare say there will be some "kits" floating on Ebay to do this if needed though.
Andy.
So pleasant to see that all models of Citroen are welcomed equally here.
Jim's comment made me think that it might be better to areldite the unused Xantia bonnets down.
Give some resistance when the crap design strut heads fail.
John
John
Xmexclusive
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
You're as warped as I am.
When I had some 605 struts serviced, they actually replaced them with 406 struts - the regasser reckoned they were a slightly newer/better item and the stroke compatible.
I've seen two Xantia bonnets bent (kinked) where a varlet has yanked on it to close, failing to observe the rigid prop.
have to admit even at 208k and 400 miles avereage a week my bonnet is never open on the hdi - only ever to borrow the battery or check oil / water which never moves.. fill washers and service.. nothing else...CitroJim wrote:It's odd because as far as I know all Pugs of that era had them (306 certainly) and the XM did..
Unlike an XM...
<runs and hides>
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- CitroJim
- x 6204
- Contact:
Re:
John, I was only joking....
Yep, I have a prime example of this sort of damage on my V6... Happened very early in the life of the car I believe...addo wrote: I've seen two Xantia bonnets bent (kinked) where a varlet has yanked on it to close, failing to observe the rigid prop.
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
"I believe the reason the XM had them and the Xantia didn't was the fact that it's rarely necessary to lift a Xantia bonnet."
Obviously didn't think of us airside workers then!! Almost every day I'm asked by security to open the bonnet.. don't know what they expect to find except an Hdi engine and a few wires of course!!
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- CitroJim
- x 6204
- Contact:
Not much room for anything else..c.morewood wrote: don't know what they expect to find except an Hdi engine and a few wires of course!!
What you want is a clear perspex bonnet...
- Donor 2023
"What you want is a clear perspex bonnet..."
Do you know where I can get one Jim? It must be lighter that this one!!
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- CitroJim
- x 6204
- Contact:
Sadly not but I'd love one...c.morewood wrote: Do you know where I can get one Jim? It must be lighter that this one!!
It would be fairly simple to make but perspex is very expensive, i remember from when i had to replace some perspex windows it cost a fortne, perspex is shaped with heat too so might not fare to well above the warms of the engine, you may end up with a vacume moulding of the engine after a long wait in traffic lol
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- CitroJim
- x 6204
- Contact:
Deanxm wrote:you may end up with a vacume moulding of the engine after a long wait in traffic lol
- Napoleon
- x 4
- Contact:
Anyone know of struts being fitted after market to C5 III?
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
