Spare wheel lock bolt
spider
x 77
Unread post by spider »
To save buying one to find out (!) does anyone know off hand what the plastic bolt size (and length) is ? , I seem to think M12 and probably about 10cm length but I've not had one in my hand for ages so not really sure.
Thanks! :D
Andy.
x 94
Re: Spare wheel lock bolt
Unread post by citronut »
for what model Andy
and plastic bolt??????
regards malcolm
spider
x 77
Sorry that would help :oops: :oops: :oops: '02 106
I was under the impression they were all the same, although if I remember correctly the 306 has a longer bolt. The plastic bolt that is sometimes fitted in the centre of the boot floor area that goes through the spare wheel to act as a vague theft deterrent.
Mine is awol and I think its best I have one given my area. Have found the wheel centre part in my toolbox :D so I only need the bolt / nut really as I want to have the spare the other way up (with the valve accessible) but I don't have one here to decide what size I need, I could guess but the correct one would be good.
Andy.
x 94
if you mean the bolt that goes through the boot floor and into the hook that holds the wheel carrier up,
here are the three lengths which seem to be dependent on tyre size
7615 96
SUPPORT SCREW
LONG 167MM
- 185X55X14 H TYRES UNTIL RPO 08635
7615 83
LONG 145
- 185X55X14 H TYRES SINCE RPO 08636
LONG 145
- 175X60X14 H TYRES SINCE RPO 08636
7615 85
CARRIER SCREW
LONG 113MM
- SINCE RPO 08636 EXCEPT 175X60X14 H TYRES EXCEPT 185X55X14 H TYRES
and here is price and part No's for each one
Reference Description Quantity Price - VAT Price + VAT Total + VAT Selection
0000761583 SUPPORT SCREW 5.10 GBP 6.12 GBP 6.12 GBP
0000761585 CARRIER SCREW 5.40 GBP 6.48 GBP 6.48 GBP
0000761596 SUPPORT SCREW 4.76 GBP 5.71 GBP 5.71 GBP
regards malcolm
spider
x 77
Thanks Malcolm.
No not those. That's the metal bolt / hook right at the back panel area. Its the accessory one I'm after, a curosory Google search turned up 96731T which sounds about right but that's the complete kit > http://www.ebay.co.uk/itm/Genuine-Peuge ... 0746421700" onclick="window.open(this.href);return false;
It may be easier to Ebay for a suitable bolt / nut. They are only plastic to prevent corrosion as they are not load bearing.
Andy.
