C5 leaking suspension
Dextraspecial
New User
Unread post by Dextraspecial »
Hello guys,
i would greatly appreciate any and all information you can give to me on this matter.
My C5's suspension is leaking from the pipe that runs from the near side (what i believe is the) hydraulic reservoir to the pump on the off side.
More specifically its leaking at the point where the pipe is anchored to the sub frame.
What is the best method of repair/replacement?
Much obliged.
cachaciero
x 9
Re: C5 leaking suspension
Unread post by cachaciero »
Well the oil reservoir for the suspension and steering is immediately behind the pump on the offside and I believe that the two small diameter suspension pipes for the rear axle run down the offside also.
I wonder if the pipes you are referring to are the pipes for the power steering, about 10mil diameter rubber pipes, weeping of these is a common occurrence on older cars, seems, in my case at least, to be due to poor crimping of the metal unions onto the pipe.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
