sound like exhaust leak but cant find hole
sean86
Unread post by sean86 »
hi all have dw8 xsara when drive trough a build up area i can hear what sound like a slight exhaust leak so took car to garage they said they found nothing,so i jack it up and took a look myself same result. any ideas? cat? thanks for looking sean
02 xsara 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
x 1238
Re: sound like exhaust leak but cant find hole
Unread post by Peter.N. »
Hi Sean
Get someone to block the end of the exhaust while you listen undrneath.
x 94
Unread post by citronut »
if its mainly on acceleration it is probably the manifold to down pipe joint as this is spring loaded, so when engine under load this can open a bit,
whilst stationary with engine on tick over you might not find a leak,
regards malcolm
sean86
ok lads will have a better look ya its only when you put the shoe down as always spot on thanks a mill sean
02 xsara 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
Xantia Dave
Unread post by Xantia Dave »
It could be a partial blockage ,keep an eye on it ,is it down on power?
sean86
no i cant say i noticed anything i opened the clamp at the back box nothing came out. i have a look around the cat and manafold today thanks
02 xsara 1.9
98 106 gti 1.6
99 xsara 1.9
98 xantia 1.8
95 405 1.9
x 94
sean86 wrote:ok lads will have a better look ya its only when you put the shoe down as always spot on thanks a mill sean
i would just get an manifold to down pipe fitting kit as it will require new springs and sealing ring,
but mind you dont buy a cheap kit as they realy need the better woven wire sealing ring/gasket,
GSF used to sell the kits
it could also mean your engine mounts are week allowing the engine to tilt more that its ment to
regards malcolm
