Slightly rough idle when AC is on - Xantia 2.0 16v petrol
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
The idle is smooth when the AC is off, when AC is switched on the idle becomes a bit rough. Is this normal ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Slightly rough idle when AC is on - Xantia 2.0 16v petro
Unread post by citronut »
maybe your AC pump pulley bearing are failing,
if this is the case mind the pulley does not cause the aux drive belt to drop off and end up behind the cam belt cover, which in turn can cause the cam belt to fail,
regards malcolm
