Why would a C-matic make a crunching sound while going into gear?
It only goes into gear at low revs with a horrible crunching sound.
Also what would prevent rear gear from engaging?
CX C-matic: crunchy gearbox
Deanxm
- x 87
Re: CX C-matic: crunchy gearbox
sounds like a dragging clutch but not knowing anything about the c-matic at all im not sure, if its an automatic hydraulic clutch with a standard manual box then i would suspect air in the clutch circuit.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
davoxx
- x 15
I wonder if it just needs a new clutch? Is changing a clutch on one of these an amateur jobby?
- edit i just realised it has no clutch .. duh me...
why?
Citroening
- x 19
They all do that, sir...
Mostly from cold too, they struggle to engage gears...
Greame (aerodynamica) will no doubt be along shortly as he knows a lot about the C-Matic box...
Franklin
davoxx
- x 15
the car does not go into reverse every and is very hard to get into any gear even when warm.
there is a bit missing on the connector rods coming from the gear stick, which explains why it was so loose.
where is the 'points' that need to be adjusted?
why?
davoxx
- x 15
i found the points, and they seem correct, they move and match the settings in the haynes manual.
ho do i check that the elctro valve is not sticking? is it just a +12v trigger?
why?
davoxx
- x 15
also just realised the rev counter does not work either .. could this be related?
why?
davoxx
- x 15
Figured out it is the electric valve / solenoid at the front. Has anyone got a spare?
why?
