2.2 C5 tuning box
x 1240
2.2 C5 tuning box
Unread post by Peter.N. »
I fitted the box to the C5 yesterday, no problem fitting it except that you have to remove the fuel filter to get to the plug and even then its tight but didn't take many minutes. Went to Axminster this morning, no apparant improvement in fuel consumption but it goes like a rocket, so there will probably be a tuning box for sale.
Chris570
x 36
Re: 2.2 C5 tuning box
Unread post by Chris570 »
was that the fuel consumption from the trip computer or from pump?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 1240
From the computer. Thier reason for it giving a better consumtion is that you can use a higher gear because of the extra power but as I rarely exceed 2000 rpm in any gear and mostly use lower revs than that I can't see how it will help. It only averaged about 35 mpg this morning, admittedly that was with a lot of stop start driving, I have yet to try it on a longer journey but it only managed 45 mpg on our trip to Kent at the weekend. If that's the best it can do it will be for sale.
Deanxm
x 87
Unread post by Deanxm »
dont forget the computer will be wrong, you will have to work it out fill to fill Peter.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
