Disconnecting vacuum hose from FPR has no effect
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
I disconnected the vacuum hose that is hocked onto the Fuel Pressure Regulator and it seems that it doesn’t have any effect . When I blocked the end of the hose with my finger I can definitely say that vacuum is there. What should be the effect of disconnecting the vacuum hose from the FPR
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Are you measuring fuel pressure with a pressure gauge?
First test for the FPR is flow, but remove and plug the hose off your intake manifold. From memory, 60 seconds with the key on but motor off, should yield over 2½ litres in a can.
Testing fuel pressure with the motor running, you will not see full pressure (3.0 Bar) unless the vacuum line is disconnected and plugged.
lancia58
(Donor 2022)
x 8
Re: Disconnecting vacuum hose from FPR has no effect
I don’t have a pressure gauge. Disconnecting the vacuum should have a noticeable effect at idle ?
Zohar
addo
x 95
No; not detectable at all.
