C5 MK2 new calipers discs pads what a nightmare
marco f1
Unread post by marco f1 »
hi all just had new rear callipers, discs, and pads fitted to my C5 54 reg and what a pain in the backside 08.30am drop off 5.45pm pick up totaly seized bent and snaped bolts, build up of corrosion on face plate having to be chipped away.. but all new parts fitted now, the garage said it was one of the worst jobs he has ever done in his life and will think again about taken on another one bearing in mind my car is a one prev owner car with full dealer service history so if you are thinking of doing it yourself have a very very very big think about it.... and do what i did give it to a garage... i hope this helps as i dont like to see any one in the s##t .......
regards
marco
citroen C5 vtr 2.0 hdi 138 bhp 54 reg mk
live life a quater mile at a time
waynedance
x 8
Re: C5 MK2 new calipers discs pads what a nightmare
Unread post by waynedance »
I removed my rear callipers last year due to the know squealing noise & corrosion, cleaned them up and swapped drivers to passenger and vice versa.
Volvo S80 D5.........
marco f1
all i am saying is if you think that thay are going to be a nightmere give it to a garage to do as thay have all the gear but if you are going to do it yourself then good luck
Richard Stevens
Unread post by Richard Stevens »
Sad story, but thanks for the heads-up, I shall check mine as soon as it stops raining!!
Did my front ones last Christmas, no problem, but the rear ones get mostly ignored.
R
1995 ZX Turbo diesel Volcane
1999 Xantia HDI
2005 C5 1.6 HDI
2006 C5 2.0 HDI Exclusive
Remember - many warnings are spurious or bad connections
waynedance
x 8
marco f1 wrote:all i am saying is if you think that thay are going to be a nightmere give it to a garage to do as thay have all the gear but if you are going to do it yourself then good luck
I am no mechanic but luckily work at a garage :)
Lighty
x 35
Unread post by Lighty »
If these caliper bolts have never been removed before, they are a nightmare to get out, I have to use ear defenders whilst airgunning them out :roll:
You would be mad to try them at home to be honest. I have found that heating up the caliper helps as it melts the "glue" that holds it all together so tight.
Best to budget for new calipers, as they are relatively cheap now, and most come with new bolts :mrgreen:
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 94
Unread post by citronut »
my local dealer told me they don't bother trying to salvage the old calipers anymore but just lop off the hole lot and fit everything new, as this is cheaper than there fitters spending 5 hour's trying to save the calipers, at dealers hourly rate at least,
regards malcolm
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Having had BXs and Xantias, I know how difficult it can be to remove rear calipers. So when my C5 was in its first year I easily removed one bolt at a time, cleaned it up, coated it with copper grease, then replaced it. The bolts have never shown any tendancy to come loose and yet a couple of weeks ago when I removed the calipers to clean and grease the joint faces and fit new discs and pads, the job was so easy.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
marco f1
hi all.. so if you are looking for a set of calipers try these guys http://www.jandrcvjoints.co.uk" onclick="window.open(this.href);return false; in birmingham tell 0121 7705636 thay do pay pal and over the phone orders, and are very plesent on the phone, i put my order in at 1.45pm and thay were on knocking on my door the next day at 3.05pm how about that for good service carnt fault them. and all the prices are reasonable too. and a two year warranty on parts .......
hope this helps i know it did for me being on a tight budget
regards
marco
x 5674
Looks good Marco. How much did you pay? I may need some for this 'new' C5. Haven't looked yet - head in sand mode activated :(
marco f1
yer mate the calipers cost me £79.99 a pair and £4.99 dell and that included the fitting kit for the pads ..... which is better than £56 for each caliper and £8.79 + vat each for the fitting kit. that is what my local car spares shop were going to charge me. so what a bargain.. these caliper dealers also advertise on ebay.. hope this helps
regards
marco
x 5674
Thanks Marco, I'm sure there will be other interested parties too. My last one, on the other C5, was £88 for the caliper.
marco f1
im glad to help... and we all like a bargain :-D and the quality is excelent carnt fault them :-D
regards
marco ( one very happy chappy )
x 94
and just a tinny bit cheaper than the dealer :shock: :wink:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00004400L3 NEW RR CALIPER 139.29 GBP 167.15 GBP 167.15 GBP
0000440721 SET 2 SHIM 13.40 GBP 16.08 GBP 16.08 GBP
0000442511 BRAK PAD SPRING 0.58 GBP 0.70 GBP 0.70 GBP
0000443203 RETAINING PIN 0.51 GBP 0.61 GBP 0.61 GBP
0000693648 WASHER-NUT 0.35 GBP 0.42 GBP 0.42 GBP
For information, these are the recommended retail parts prices of your
country. Initial estimate pending dismantling and depending on the condition of the vehicle.
Total excl. VAT 154.13 GBP
Total incl. VAT 184.96 GBP
and this is for one side only
regards malcolm
