synergie glow plugs.
dave2011
hi guys.
ever since i bought my p reg synergie its allways had a button to opperate the glow plugs as at some point in its life the relay module box for the glow plugs has packed up.i picked up a replacement module to fit off a scudo van with the same engine in as mine as i bought the power steering pump off it and its slightly different............
on mine the underside is green with a black outer case and the multi plug fitment on it is labeled 1 to 5 .......on the replacement the whole thing is black and a bosch branded one where i think the origional one is a cheap crappy one.....also the wireing labeled one to five is the other way round and missing a pin. would fitting this to try it damage anything? ecu/immobilizer ect ect .cheers guys
