c5 abs
mm1
c5 abs
Unread post by mm1 »
hey guys.have a 2003 c5 hdi.the abs and service light has come on.
local mechanic plugged it in to the computer and came up with faulty
abs pump.new one from citroen is 850euro.he has tried fitting a
second hand one but to no avail.he said the part numbers have to be identical
which is proving very hard to get.has anyone had this problem and is there an
easy fix.thanks in advance.
mm1
Re: c5 abs
bump
DickieG
Monaco's youngest playboy
x 38
Re: c5 abs
Unread post by DickieG »
A friend had this same problem on a C5 recently, apparently there are two types of pump and from the sound of it your car has the same/rare one. He managed to find a second hand replacement, fitted it and all is now working well, I carried out a diagnostic session on it and the previously recorded faults have cleared so it would appear that provided you can find a decent replacement pump of the same type its simply a case of fitting it.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
cachaciero
x 9
Re: c5 abs
Unread post by cachaciero »
Do we (collectively) know what the differences are between the pumps? when we say pumps do we mean pumps or the complete ABS block?
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Lighty
x 35
Re: c5 abs
Unread post by Lighty »
I use these people, they usually repair for about £200 http://www.ecutesting.com/contact_us.html" onclick="window.open(this.href);return false;
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
mm1
Re: c5 abs
i presume its the whole abs block he's replacing.have check several second
hand pumps.the numbers on the front are the same as mine but the
numbers on the back are different.is it the numbers on the back that
really matter?
