Anyone changed a Doseur valve?
wrinklet1
Well I have to change mine so if you have any tips please do tell.
Paul
Paul
tomsheppard
NiSk
stewart_c
algieuk
Which car Paul? Got a friend to do mine tonight on a 94 Xantia 1.9D. Problems experienced were sticky fingers from leaked LHM in footwell. There are only 4 steel pipes, which all came out no probs. Make sure you have new clips to put on the return pipes (2 off). You will also need a deep socket set (1/4 in drive is best) to remove the nuts inside the car. Taking out the push rod makes the job a lot easier (lever up inside the pedal with a screwdriver and it comes out a treat....get rid of the spring while you are at it). Make sure you have 2 11mm open end spanners to lock the nuts on the studs of the old unit to remove them. Hardest part of the job was finidng a repalcement 11 mm nut for the one that had a damaged thread. Took about 1.5 hours workng in a very relaxed fashion, but if you were determined, and had done one before then half an hour would see it done. Haven't got a clue what the locking collar Haynes refers to is...I never saw one.
blueboy2001
Half an hour to change a brake valve! Citroen dealers will be queueing up to give you a job! Citroen book time is 4 hours labour. Can't see why you needed to go into the footwell, the bolts just came out with a socket when I did mine.
Took me and a mate over 3 hours to do mine, and that was working solid on the job. Ended up using a set of snap-on midget spanners to remove the pipes. The return hose decided to split on refitting so had to be replaced - about £40. The position is so awarkward you will skin your knuckles.
I've said before and i'll say it again, are you absolutely sure the valve is faulty? These are of a dead simple design and I can't really see, given they are immersed in mineral oil all the time, how they would wear out. Changing mine made not a bit of difference to the 5 seconds hissing noise and rapid sinking.
alexx
Well, it made huge difference in my BX; ticking interval increased from 5-10 s to about 1-2 min. I dismantled the old valve after fitting the new one, and the first piston (for front brakes) was visibly worn (although probably only 1-2 micrometers) on the edge.
The problem is - part of that piston, that seals the pressure up to 170 bar, is only about 1.5mm long, so this can't last forever. This part was longer on CX/GS type brake valves.
As I said several times, there's a simple test - observing output from return hose. In my case, it was about 50 ml per minute, dropping to about 5 within several minutes after brake pedal was touched last time, with ticking interval increasing accordingly.
Unfortunately, there were no Citroen forums 6 years ago, and 5 different mechanics here didn't have a clue about this problem, so I had to discover this myself.
tomsheppard
algieuk
Citroen expect 8 hours to change a clutch cable so 4 hours for a half hour job sounds about right.
I had to change my valve because the seal at the end had gone, and the return flow was squirtng over my shoes instead of going up the pipes.
I can't imagine how you managed to take 3 hours to undo 4 pipes, 2 hose clips and two nuts. Access is great compared to a BX.I don't suppose you tried to undo all the pipes BEFORE you undid the securing nuts did you? (that WOULD make it a hard job).
Like I say, My friend started the job at 5:30, it was done by 7 and in the meanwhile his missus brought us two cups of tea which we drank slowly, we chatted to all the kids who came and asked us what we were doing, we spent half an hour looking for a new nut to replace the one with damaged threads and we spent a while shooting the breeze.
And how did you manage to undo the securing nuts without going into the footwell? they are behind the brake pedal.
Dave Burns
"I can't imagine how you managed to take 3 hours to undo 4 pipes, 2 hose clips and two nuts"
I can, 1.9D against 1.9TD, that bloody turbo makes a world of difference if you don't shift the air ducting, and thats no mean feat if you want it right out, plus the sx probably has the aircon refrigerant pipes in the way aswell.
Dave
Dave
jeremy
I thought I would do the Doseur on my TD BX last year but after I'd bought the valve I funked it as I wasn't sure I could get the bottom pipes back and thought I could end up stuck with a dismantled hydraulic system. I asked my friendly mechanic to have a look as he could get at the bottom ones on his ramp - he took one look and said no - for much the same reasons I'd done. But he did recommend me to an experienced citroen mechanic who did the job very well. I believe he dismantled the bottom engine bracket and swung the engine forward (having put hardboard over the radiator) to gain more room.
Jeremy
Jeremy
blueboy2001
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tomsheppard</i>
Blueboy, Have you still got the fast ticking and sinking problem?
Yes, but mine makes an awful hissing noise rather than a sharp tick as it should do.
Indeed on the TD, we had to remove the intercooler piping and the rocker cover to gain satisfactory access to the valve. On mine the bolts were on the bulkhead side, just undid them and put them back in on the new valve. The new one is solid so I assume I've done it correctly, certainly the bolts seemed to bite the threads in the right way.
jeremy
tomsheppard
