1999 xantia central locking issue.
Chris570
x 37
Unread post by Chris570 »
My lovely HDi has decided to lock then unlock immediately whether locking on the key or plip. the Lexia says there is a permanent fault with the LH Door button. All doors lock and unlock ok with the actuator test. So, does anyone have an accurate wiring diagram or suggestions?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
DickieG
Monaco's youngest playboy
x 38
Re: 1999 Xantia central locking issue.
Unread post by DickieG »
Check the harness connection block on the lock, I've come across problems there on a few Xantia's now causing the exact same problem.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Chris570
x 37
Cheers for that, checked both n/s doors and all connections are ok but i did find a broken wire in the rear one, which explains why the window doesnt work. all the other wires seem good so ideally now need a diagram so i can check continuity back to the cph.
sodding rain has stopped play for now
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
DickieG
x 38
Using Lexia have you observed live info on the locking state of each door? Normally with such a problem of the locks immediately unlocking it's down to a problem on the front door lock/s.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Rhothgar
(Donor 2026)
x 225
Unread post by Rhothgar »
Hi Chris
Where are you based?
I have a complete set of Xantia Dealer Level Workshop Manuals including Electrical Diagrams. They take some understanding though.
Chris570
x 37
with the lexia you can lock the doors and deadlock them successfully, as far as i can see from the available menus everything is working as it should.
Roth, i'm in bedford
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
DickieG
x 38
Chris570 wrote:with the lexia you can lock the doors and deadlock them successfully, as far as i can see from the available menus everything is working as it should.
What does lexia show when you are looking at the perameter menu for the locking state of the doors? It might show which door is causing the problem by one showing unlocked whereas the others are locked helping you know where exactly to direct your attention.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Rhothgar
(Donor 2026)
x 225
If you fancy a journey up to Nottingham sometime, you can come and use my manuals.
Chris570
x 37
Cheers for the support so far :)
i've found the issue it's pin 3 on the drivers side door motor back to the CPH that has a break in the door shut.
I've started to remove the glovebox to get to the CPH (and kill the traffic master if I feel like it) but i can't find the screws holding the bottom of the glovebox in.
any suggestions?(for when the rain lets up:( )
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Feel for the dimples in the felt. There's one in the left corner; can't remember the others offhand.
Chris570
x 37
oh actually inside the glovebox?
i've removed the carpety felty thing underneath it and can't see/feel anything
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
x 95
Yeah, the thin felt what's stuck on the glovebox "floor".
addo
x 95
OK, aside from the perimeter screws with rubber buffers, there is one on the lower right flange - clearly visible to the eye, and one in the centre of the lower felt near its forward edge. Then there's one in the "back" felt on the left lower corner.
Rhothgar
(Donor 2026)
x 225
Some good tips there, Adam.
Must remember these. Save me breaking the glove box off next time!!! :oops:
