Right, the old girl is doing me proud at the mo....
Drove up from Plymouth to Nottingham yesterday with three of us on it and my foot down. Got back on £40 which works out as 44 mpg which I'm happy with. (I do have a lead foot!)
She rides great, stops well, the engine is sweet (except a rattling bottom pully) and the performance is great.
However, just a few jobs left.
-Still got the side airbag light on. Goes off after starting but comes back on after a few seconds.
-Slight judder from the front under heavy braking. Warped discs?
-Steering heavy when first started. LHM flush needed?
-Cooling fans still not working. Relays changed. Duff motors?
-Finally, just a real eyesore, the front seats have fag burns in them. Is there anyway of getting them repaired or is it just best to keep looking for a better set? Grey with small rhombus shaped dark grey pattern.
Many thanks.
HDI 110 Xantia jobs nearly done.
Stepto1
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
c.morewood
- x 55
Re: HDI 110 Xantia jobs nearly done.
Try to spin the fans by hand (with the ignition off they're sharp) as sometimes they get stuck in one positon.. mine did anyway and the motor wasn't enough to turn it. Also when I remove and replaced the relays I found a good bit of corrosion on the contacts.
My aribag light turned out to be the connections on the white connector under the seat. I just carefully put a very small screwdriver between the plastic and the metal connector and bent it very slightly so that contact was remade when the two connector halves were put together. Ihope that makes sense.
I hope that helps.
I hope that helps.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
Stepto1
Thanks Chris, the fans spin freely so will check elsewhere.
I'll have a look under the seats for that white connection.
Steve.
Steve.
