Hi folks heres a scenario you've all heard before. Three beeps, flashing snowflake etc. I have been told many things from get the codes read etc but its a very intermittent fault and doesn't come up with any codes.
My particular problem only occurs when the sensodrive is trying to downchange itself when slowing. It isnt releasing the clutch and is effectively trying to change without it. It is not the actuator as you can drive the car perfectly well when using the paddles and if you turn the car of then back on its back to normal.
So what actually controls the downchange. Is there a relay I should look for or is there a sensor. I have had the gearbox ecu updated last year. Any help would be gratefull thanks
Sensodrive experts please
spandelly
Re: Sensodrive experts please
I only need to know what controls the downchange anyone please
DickieG
- Monaco's youngest playboy
- x 33
I can't help you specifically with the Sensodrive issue other than to say that if it was my car I'd use a diagnostic tool (Lexia) to observe the gearbox operation as it was being driven, there may also be various actutor tests which can be done by Lexia which will assist in pointing a finger in the right direction. Reading fault codes is a very small part of using diagnostic tools, has the cars fault code history menu been accessed? This is different from standard fault code reading as this is a record of fault codes as they appear and are then cleared, I'd be very surprised if something isn't recorded there.
If you're anywhere near to the west of London I'm willing to take a look at the car using my Lexia.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
spandelly
Thanks for the reply I'm in manchester myself but thanks for the generous offer. I haven't had them read by lexia but its a common problem that I have only heard come to the same outcome of changing the actuator (which can only be done by citroen as its a coded part ). Apparently they all come up with the same code of actuator faliure which is not the problem I have. There have been many people who have changed the actuator just to have the fault re occur within weeks so I was hoping I could trace the fault myself and put an end to mine and a lot of other peoples problems with a more specific answer. The thing thats bugging me is that the actuator itself works fine. Its just that whatever sends the signal to the actuator when the car is slowing isnt sending that signal so if I know what that is then I have a starting block to work from.
