c5 HDI limp mode
jonesbri
c5 HDI limp mode
Unread post by jonesbri »
Can anybody help me please.
I am trying to repair my daughters car. It has poor acceleration. I think limp mode.
It is a 02 registered Citroen C5 HDI
The engine management light is not on when running.
I have been useing a lexia diagnostic tool.
It indicates 3 problem areas.
1. Instrument panel fault
2. Radio post- equipment fault
3. Suspension fault P0306 permanent
I have ignored the radio equip fault.
When diagnosing the suspension fault, I tried to activate front and rear hydroactive solenoid valves it gave me an error, not sure if this is ok.
I would appreciate some help please.
KevMayer
Re: c5 HDI limp mode
Unread post by KevMayer »
Hello and welcome to the forum.
Which engine does the C5 have. Is it 2.0 or 2.2 Hdi?
How many miles has it done?
Are you sure the Lexia has accessed the engine ECU?
Cheers, Kev
cachaciero
x 9
Unread post by cachaciero »
1 is often a phantom fault.
2 is definitely a phantom fault.
3 Is a genuine error.
Poor acceleration with no error codes is likely to be a stretched accelerator cable, you should not be able to lift the peddle up at rest, if you can the cable is slack.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
jonesbri
Hello kev
The car is a 2.0ltr and has 148000 mls up on it. It is still in good nick.
I dont quite understand your last question. I am not overly familiar with lexia. With the ignition on posn. 2 lexia communicats with car it verifies the vin #, I go into dignostic and then global test. Some screenshots are shown in attached outputs.
Hope this helps
x 2938
It's a pedal Cach not a peddle :)
jonesbri
Hello Cachaciero
I checked the accelerator pedal. It has 1 inch movement upwards but it still has 3 inches of movement downwards. Which seems to be plenty to get the apropriate power when moving away from standstill .
I have just monitored the car. I starts on the button. Idles at around 800 revs. which seems to be normal. If you put your foot on the accelerator down slowly. It seems slow to pick up until it reaches around 1500 revs. then seems to accelerate as normal.
cachaciero
x 9
jonesbri wrote:Hello Cachaciero
1 inch corresponds to 25% of the total movement, which is about the same as mine was when I first had it, removing the slack made quite a difference to the perceived engine performance.
As to the acceleration characteristics of the engine that would seem to be reasonable, the turbo doesn't start to work and produce meaningful boost until about 1500 rpm so I would expect the acceleration to be about as you describe.
Caveat I don't have any experience of the 2.0 ltr as such.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
x 9
Gibbo2286 wrote:It's a pedal Cach not a peddle :)
and not a paddle either :-) there are times when the single brain cell just gets it wrong :-)
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
