Xantia Battery Drain
allanmc
Unread post by allanmc »
I have had a problem with my battery draining since last May I was reluctant to put this on the forum as I had taken the car to a guy with a Lexia who diagnosed the fault being the Injection Relay but after buying a new one the problem is still there, the guy with the Lexia said he would get the wireing diagram from Service Citroen but was unsuccessful as of last month so I hope someone here can help,I will explain what I can, at first I disconected the batt. but then discovered if I withdrew the No. 25 fuse the Batt. didnt drain, now among other things the CPH is on this fuse, but is also on No.1 and 15 fuse but when these fuses are drawn the batt. drains hope someone can help.
allan
Xantia 2.0i SX Auto, 1999
citroenxm
Fallen Hero
x 70
Re: Xantia Battery Drain
Unread post by citroenxm »
What year and what engine is your Xantia... that will help us out a bit more!!
What spec level too is the car, LX, SX, Exclusive??? etc....
A very sad...
1994 XM 2.1 d auto
allanmc
The car is a Series 2 Xantia SX 2Ltr. HDI 110 BHP year 2000
allan
beast
Unread post by beast »
Hi Allan I have a series 2 xantia hdi 90 bhp I have a similar problem car only has to sit for only two days on the drive and it is completely flat bought a new battery thinking it was a tired one and hey same problem so what you saying is in your post that when you take out fuse no 25 the problem is gone you have no issues I'm no expert can someone explain what the cph is bit fed up getting jump leads out to start the car.
