ABS block
KennyW
x 165
ABS block
Unread post by KennyW »
On the ABS block which pipe goes where :?:
Will be changing the rear supply brake pipe soon.
Kenny
C3 1.4 petrol (SWMBO)
citroenxm
Fallen Hero
x 70
Re: ABS block
Unread post by citroenxm »
Ah.. Ive just done one of these... The rear supply pipe is ONE WHOLE single pipe from the K joint at the rear to the ABS block. Now, how do I explain, the pipe is I THINK, looking at the block in situ, theres two pipes nearest you, and its one of those. Put it this way its the THICKER pipe.. The Top pipe is the feed to the rear, the lower to the front...
The other pipes are smaller 3.5mm pipes from the brake pedal valve.
I ll need to check to be certain which of the 4.5mm pipes goes to front and which to rear.
The brake feed K joint is attached to the underside of the rear subframe, on the passenger side.. but the feed pipe loops out and over the top of the subframe and then down past the fuel tank and along the car..
A very sad...
1994 XM 2.1 d auto
KennyW
x 165
Re: ABS block
Thanks top rear 4.5mm,perfect. Now to follow it back to the k connector :lol:
Kenny
Here's a pic
